is the tst really that good?
i see alot of people running the tst with the bdtd or the smarty. is it really as good as i have been lead to belive? i think it is. i really wont to make alot of power and am def interested in getting the tst r-49 after i get my clutch put in next monday. so befor i go and spend another $900 on somthing i want to make sure i dont have to rebuy again...so is it worth it?
Hope you have better luck than me.Mines been off more than on.This is my (06) though (05) worked fine most of the time but the (06) dosnt work for CRAP! CODES!after CODES!There going to look at it and see if they can find out whats wrong with it. HOPE SO!
Good luck with them finding the problem. I drove my truck to TST after 2 weeks of codes and trying different grounds and everything they told me to try after many phone calls. They messed with it for 5 hours trying new wiring harnesses changing ground location, different boxes, and whatever else. Then Mark finally told me they couldn't get to work and he would return it no problem, So I returned it but ****! I wanted that power! So I put my Edge Juice back on and then stacked it with an Edge EZ box after talking to Edge about the stack cause so many people on here had me believe that the juice for the 03 had pressure allready. Edge said that was not true and I got the EZ box, And that really livened my truck up. It was very slow to rev up with only the juice I thought but it really works well with the EZ. My thoughts on the TST is that the early models may work on the 03-04 trucks but they must have had to play with some circuits inside to make them compatible with the 05 and whatever they did screwed them up for the 03. I wish I could get a "early" design box that works.
I love my R49 also. The Cool Down Timer feature is great along with pretty much unlimited power options.
I mounted mine with a Universal Profit International mount. I have used this mount for many things on and around the dash before.
I had some problems...or so i thought...with my TST. I took my TS MP8 out of the mix and problem solved!! but HOT on a stock turbo
I was running the TST on 1/1 and the Crazy Larry program....it was awesome...til the stock flex plate shattered when the tranny hit 3rd. just unscrewing the bell housing, metal flakes were already falling out!
A buddy of mine had problems with his first attempt with the TST.....wouldnt even idle. We put my TST on his last night and it was working well...very welll...until...we had a mishap
i swears its like my TST is cursed or something...but man its FUN!
My remote is/was/will be mounted in the ash tray. COMPLETELY out of sight until you flip open the ashtray. Very sneaky in my opinion...i like it.
My (03) and (05) worked fine but like i said the (06) is having problems.The truck runs ruogh then starts throughing codes low boost low volt over boost rail pres,to high and so on.took it off truck runs great!Put the BULLYDOG on runs GREAT its got to be the (TST) and the TS MP-8 works GREAT.
NOT BASHING THE TST I JUST GOT A BAD ONE!
