TST question
TST question
Fixing to be buying a TST off another forum. Guy is not fimiliar with tst so doesn't know which version it is.. I know it has built in gauges on the remote so Im guessing its at least the CR47 model.. Anyway to tell if its the cr49 besides having the built in programs? SN is #1897 but whos to say it has not been updated to cr49? How do you scroll through the options on the remote to tell if its a cr49 for sure?
TST powermax
The units with rail pressure capabilities, adj timing, adj boost limiter, egt limiter, and turbo cooldown timer are serial numbers 5000 and above
Correct so cr49 from tst thereself will be SN 5000 and above? But if this box was sent in to get the upgrade to cr49 would they change the SN on the box?
bump... when cycling through the options on a cr49? Can you just push the grey button. It will go through options hp then tq and then what?
Ya but even if I give them the SN it may have been updated before. Im gonna find out tomorrow. Im gonna have the guy push the grey button and see what comes up after hp and tq setting
He said when he pushs the grey button to cycle throught the settings it only does.. Hp then tq then max egt and then boost... What yall think cr47?
