TST issues
TST issues
Okay, i dont know for sure what my problem is,so here goes---- im setting code 608 480 and 366. My truck will be driving along and die * KAPUT *. I will mess with the key on and off on and off for a minute or so. And it will then start. Wether or not it stays running is another issue. It does this consistently, i have astro start, i let my truck run for around 2 minutes, and then it dies.. the only way it will not calve on me is if im at around 2000 rpm or more. I can actually feel the truck start to defuel or whatever its trying to do. but it works its way past it-- at a high rpm level..... it has been doing this for 2 days now......
What I would start to do first is do the process of elimination, 1st pull off you EZ and see if that cures the problem, if not than put that back on and take the TST off and so forth. Have you checked your fuel pressure? Mike
mjpalmer
05-19-2005 11:34 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
