TST or Hot Juice
TST or Hot Juice
I have an 05 dodge which I plan to drag race and daily drive. I am going with twins, etc.. I want a fast truck. Which should I get? I was told the Hot Juice was rated at 180hp from an Edge rep. However, I know the TST provides the power. I plan to stack it with the Edge EZ for max power. Any thoughts?
I really like my TST and having it adjustable in smaller increments than the Juice that is if it was even available for the 03-04. I also like that the Juice with Attitude has the high recalls and trans slip detection for the auto guys.
the monitors on the juice are out to lunch, it says my trans slips 6% give me a break since when does the 48re shift hard and fast even with the shift kit it said that, just turn all the backdowns off and your get a solid 90-100 rwhp and 180-200ft lbs with it, but max torque was at 2800 for a quick spike that is why this chip doesnt pull heavy loads as well as others, thats why i switched back to the tst.
DTR Advertiser
The TST will stomp the Juice in power. The TST can be run on level 1 and get timing only for incresed mileage. You cant do that with the Juice. Mild pressure, like level 1 on the EZ will add more mileage when coupled to the TST.
Don~
Don~
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
pecandude1
05-02-2005 09:41 PM
