TST and EZ
TST and EZ
I was looking at the forums on TDR and a guy had a post with Dyno numbers form an EZ stacked with the TST. I guess my question is where can you plug both in and why would that be benificial....i don't know a whole lot about these boxes...obviously
The TST box plugs into the MAP sensor (so the TST box sees actual boost numbers). The EZ then plugs into the TST's MAP connector (which would normally plug into the factory wiring harness), and the other connector from the EZ connects back to the factory wiring, like this:
MAP---TST---EZ---Harness/ECM
It's beneficial because the higher rail pressure delivers more fuel per unit of time that the injector is open, which means that the same amount of fuel is delivered sooner, keeping EGTs a little lower, and giving a little more power. The net effect is that you can turn down the TST (thereby decreasing duration) and achieve the same amount of power, only with reduced EGT's (because the combustion is happening sooner in the power stroke than it would be with just the TST box alone).
(And yes, those were my dyno numbers. 1/4-mile times coming soon )
still workin on 500
Once I get a larger turbo, I can increase the TST settings, and I'm sure I won't have any problems whatsoever hitting (and exceeding) 500RWHP.
1 Post
Tom488,
What kind of abuse have you been giving the DD turbo with the TST? I'm assuming it is their HX40 Jammer? Have you been driving it like you stole it or easy on, easy off the go pedal? Just curious, as other than not blowing quit enough air on the upper levels of the TST, they seem to be virtually indestructible. Your experiences?
Yes, it's their HX-40 turbo. I've been very happy with it, and if it holds out until I get a larger turbo on there, I'll be even happier
mjpalmer
05-19-2005 11:34 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
