tst early twins?
tst early twins?
anybody think the tst early twins is slowing me down at the track. seems the tst standard version runs a little faster at the track. my feeling is it fuels so hard so quick that it puts the cp3 working so hard to rebuild rail pressure. truck is down right now so now is the time to send it in if im gonna do it. any opinions on this?
Upgrade to the R49 with multiple programs and timing controls. Then it will be easier to find the right tune for your configuration. Upgrading was well worth it to me. Just my .02. BTW with my configuration and stack the 05twins program produced my best ETs.
i thought about upgrading but my god i have enogh trouble with ez. bddl and tst. cant imagine how many combos there would be with 3 or 4 tst programs in the mix lol. i may end up doing it though. ive heard a couple of times that the tst twins slowed people down in the 1/4 thats why i was thinking about it. can they upgrade my r 37? its one of the very first ones.
The dual feed line violates a standard design practice in fluid dynamics. It feeds pulsing and pressurized fuel into the rail @ nearly the same location on the rail, but one on top and one on bottom. Directly opposing one another.
Perhpas the dual feed is doing something I dont understand, but the basic idea of the feed locations is wrong on paper.
Try the rail with a single inlet and see what happens.
Winter fuel and even winter blend ULSD may be part of the problem as well.
tst
i just finished installing twins and i am also having problems with the bddl and tst early twins, my truck with the bddl on preformance mode and tst on 4x3 will only make 30 lbs of boost and runs like ^%$#. and so far (15.60) is the best time i can get .fuel press is ok , rail press is ok it just will not pull like it should. hellp please!
don, really no problem. the truck runs like a dream. just wanted a little better time in the 1/4. 3 is the highest i can run my tst currently and 2 is the highest without the dual feed line. i just put a helix 2 in my truck. same break in as a second gen? 1500 rpm for 15 min lots of lube?
ramwheelsby4, i will call then in the am about doing that. thanks
CACalomino
20
06-26-2007 07:19 PM
Heston_ram3500
12-15-2006 09:54 PM
