TS MP8 whats it like
Old 12-01-2007, 10:13 AM
white250005's Avatar
I have been hearing about alot of people that are stacking the mp-8. What all does this thing do? How good is it? Is worth the purchase and replacing it with the hot juice?
Old 12-01-2007, 10:17 AM
Luvnacumns's Avatar
I don't know what the hot juice is like but the mp-8 is very nice... You can definately tell a difference in power and it is easily adjustable.. I have yet to install my rail guage so I don't run it over 40% whic is what they recommend.. I had it stacked with the smarty. Mark(53 *****'s) has the smarty right now but I love the stack... smooth and reliable power... Tranny just hates it!!!!
Old 12-01-2007, 10:31 AM
JD Dearden's Avatar
you still have a stock tranny you tranny
Old 12-01-2007, 10:33 AM
omaharam's Avatar
No replacy - stacky
It is a pressure only module. Your Juice does not add pressure, so they work very nicely together. As Shane said though, without a rail gauge you want to keep it around 40% - especially with stock injectors. A good fuel filtration set up and some Flux injectors and I run mine about 75% and see about 27k on the rail gauge.
Old 12-01-2007, 10:35 AM
Luvnacumns's Avatar
Yep this spring... We are adding on to the house so my tranny funds went out the window!!! LOl.. Gotta keep momma happy!!
Old 12-01-2007, 10:36 AM
omaharam's Avatar
Originally Posted by omaharam
No replacy - stacky
Oops, didn't see your injectors at first. Do you have a 2mic filter? Either way, I guess you still need a gauge to run it over about 40%. the other factor would be if the BD adds pressure or not - I have no idea on that one.
Old 12-01-2007, 10:39 AM
JD Dearden's Avatar
I understand that do understand how big of a differance that tranny is going to make
Old 12-01-2007, 10:59 AM
boss1's Avatar
I run mine on 100% almost everywhere I go, stock truck otherwise, with no gauges...Ts says it won't raise beyond what Bosch design said they were capable of handling...sorry I don't remember exact specs, something like 100% was 28000psi and were capable of 30,000psi without harm, just my 02.
Old 12-01-2007, 11:39 AM
jgiachino's Avatar
I'd be careful on that line of thought....now sure what year truck you have, but i was under the impression that anything over 27k of rp is playing with the devil and puts your pressure relief valve and injectors (stock) at significant risk.....even the big boys with a ton of HP (and supporting mods) dont appear to run at 100% on the MP8
Old 12-01-2007, 12:09 PM
omaharam's Avatar
Good luck with that!
The safe mark on a stock truck is more like 25-26k. Maybe you'll get lucky. If you don't crack an injector running it like that, you should probably go buy a lottery ticket.
Old 12-01-2007, 02:29 PM
surfram's Avatar
How does the MP-8 compare to the edge ez on a 03-04 305/555 motor? What are the rail pressures on 40% with the MP-8? Would it be comparable to running an edge ez on level 1 (40hp/150tq)? After I get an exhaust, I am planning on a tow box and gauges.
Old 12-02-2007, 02:55 AM
Billm2004's Avatar
I ran mine at the track at 100% too and no problems here. Never saw over 27K
Old 12-02-2007, 03:45 AM
Mighty Goat's Avatar
the MP8 is a vey QUICK way to crack an injector. Get some injectors before you turn it up any further.
Old 12-02-2007, 08:28 AM
boss1's Avatar
I bought an o7 with the 6.7, been installed for a couple of months now driving about 75 to 100 miles a day and no problems yet, are these injectors the same as the 5.9's which I suppose you guys are referring to?
Old 12-02-2007, 08:26 PM
SlowSixSpeed's Avatar
I've been playing pretty hard with my mp8. It sees 100% at least twice a week for the past year.
I'm stacking it with a smarty and it pulls so much harder with it on 100% vs 40%.....I just cant help it sometimes its so freaking fast on 100% with my mods!!!!
I find myself using it more often because I dropped down to the 60hp smarty because it drives better and crank up the mp8 if anybody wants some.
Yeah I know its not good for the motor but it isnt like I drive it every day at 100% WOT.
It sure fuels my big silverbullet.
I thought 03-04 injectors were less prone to problems.
Quick Reply: TS MP8 whats it like
