True Milage on 2003 with Edge Juice / Atitude
Old 01-26-2007 | 10:14 PM
jpajax's Avatar
Smile True Milage on 2003 with Edge Juice / Atitude
I've got a 2003 Quad Cab twd 48re, 373, swb, swd, baffle removed ,silencer ring removed, tone ring mod. and Edge Juice / Attitude on level #3 got 23.78 mpg 40% city 60% highway hand calculated. Filled up at same pump with fuel at the top just before the return hole both fill ups. This is compared to 20.5 mpg stock before all these mods.. Can't wait to see what it will be towing my 29.5 fifth wheel which before could not get over 10 mpg. flat ground with tail wind.
Old 01-27-2007 | 02:29 AM
pet05's Avatar
So is it true that in the #1 setting the Juice Attitude gets better MPG than stock???
Old 01-27-2007 | 04:22 PM
jpajax's Avatar
Haven't run a test on level #1 that is were it is now and I'll let you know when I fill up again if there is difference between level #3 and level #1 but there is a big difference in stock and level # 3. The reason I tested it on level #3 is (old age) I forgot it was on #3 until I was several miles up the road.
Old 01-27-2007 | 07:05 PM
SupaDupa's Avatar
Generally, most boxes will get better mileage on the more extreme levels.........if you can keep your foot out of it!!!!
Old 01-28-2007 | 12:32 AM
pet05's Avatar
SupaDup stated:
"Generally, most boxes will get better mileage on the more extreme levels......"
Why would that be??
Old 01-28-2007 | 12:40 AM
3500lly's Avatar
My experience with the edge on an 04 dmax and my 06 cummins is that I did not get better mileage on level 1. I've heard a few other say the same about edge and say otherwise. But I do like the power gains from this setup. When stacked with bullydog on my 06 I've seen significant gains in economy
Old 01-28-2007 | 06:26 PM
jpajax's Avatar
You know how it is when your like a kid with a new toy you can't resist you have to kick it up and put it down. When you do this in level #5 it's 5 mpg but a lot of fun. I do have a question about low boost fuel adjustment, when you have the option to select 1-5 if you select 5 being highest what does this do for fuel mileage. I don't know what it might it be about the higher setting getting better mileage on some vehicles but it might be that the timing being increased.
Old 01-28-2007 | 10:16 PM
CG98x's Avatar
I would say that the increased mileage on higher settings can be linked mainly to the increased timing as mentioned earlier. That is if you can keep your foot out of it to not use all of the extra fuel. I have seen my mileage go from 10-20 MPG on the same settings depending upon how I drive. I am surprised to see how much of a gain you got out of the juice. With mine I could get maybe 1 MPG at best.
Old 01-29-2007 | 12:25 AM
3500lly's Avatar
I am fairly ingnorant when it comes to programming, does the edge add an injection pulse or is it all in timing?
Old 01-30-2007 | 05:58 PM
jpajax's Avatar
I to am not very savey when it comes to electronics but when it comes to costumer service the people at Edge are supper nice and quite knowledgeable and very willing to help. That is why I went with the Edge product. Just go to Edge web site and get their tec. # and give them a call.
Old 01-30-2007 | 08:56 PM
Reel Native's Avatar
Does the Edge throw off your overhead? I went from 18 to 13 after installing mine. I have not checked it by filling it up yet but why is there such a difference? I didnt change my driving habbits or anything else since the install.
Old 01-31-2007 | 09:05 PM
boyhowdy's Avatar
My 03 got 21 in city and high as 26 mpg with edge set at med level 60hp. Mod's were 4'' mrb ex,afe intake system, and edge ez. Wished i had that truck back, new 06 10-13mpg with same mod's. Mileage was done by hand and over head allway read high by about 2mpgs.
Old 01-31-2007 | 09:23 PM
jpajax's Avatar
Sorry I can't help you about the the over head my truck doesn't have one.
Dually Driver
13
11-13-2007 10:10 PM
yung cummmins
17
09-17-2007 10:16 PM
yung cummmins
13
09-17-2007 05:45 PM
Djasik
09-10-2007 01:51 AM
2006 MEGACAB
12-30-2006 11:39 AM
Quick Reply: True Milage on 2003 with Edge Juice / Atitude
