Truck sputering
Truck sputering
im in race mode on my edge and not all the time but somtimes as i increase speed it sputers kind of stalles and then takes off again what could cause this any help would be great
Administrator/Jarhead
When you turn the edge up, it can demand more fuel than your stock lift pump can supply, or drain the rail by demanding more fuel to the injectors than the CP3 can flow at lower RPM's. (and higher RPM's)
I would suggest getting these gauges if you are planning to run the edge on higher settings. I would also add an aftermarket fuel pump, and upgrade your CP3 with a DIY kit to get more out of the edge.
Watch that pyro, the edge runs pretty warm...
brandon507
23
07-16-2004 07:32 PM
sandpuller2004
14
06-04-2004 12:14 PM
Herve
23
03-07-2004 10:24 AM
