Trpple dog crazy larry or Smarty?
Old 08-07-2007, 09:15 PM
perfectlawncare's Avatar
I have a 05 3500 4x4 auto with a Dtt trans and I am curently running Bully dog with crazy larry + low end power. It runs like a scared rabbit. I was thinking about buying a smarty beta but should i. What is the difference between them?
Thanks for your input
Old 08-07-2007, 09:17 PM
duranator06's Avatar
I love my crazy larry great power
Old 08-07-2007, 09:19 PM
973604x4's Avatar
this is like a Dodge vs Ford question.....everyone will NEVER agree
Old 08-08-2007, 10:43 AM
DTR 1st Sergeant
soulezoo's Avatar
You got that one right!!
Old 08-08-2007, 11:22 AM
dodgeboy59td's Avatar
Bullydog!!!!!!
Old 08-08-2007, 11:26 AM
tcr
tcr's Avatar
SMARTY!!!!!!!!!!!!!!!!!!!
Old 08-08-2007, 12:57 PM
TX_Diesel's Avatar
TASTE GREAT!!!!!!!!
sorry i had to
Old 08-08-2007, 01:00 PM
DTR 1st Sergeant
soulezoo's Avatar
Less Filling!!!
Old 08-08-2007, 07:15 PM
Rob C's Avatar
Where are the cat fight girls?!?!?!?!??!!?
Smarty! with all of the smarty updates there are like 210 smarty settings compaired to 6 on the Bully (3 with low end enabled, 3 with out low end enabled) The smarty can be fine tuned to what you want and need.
Old 08-08-2007, 07:22 PM
973604x4's Avatar
Let's not forget that the Bullydog is adjustable on the fly and can adjust your speed and rev limiter! Plus it has other options like the PTO and Torque Management on or off.
See, there's no right or wrong answer. It's personal preference.
Old 08-08-2007, 07:23 PM
Out Back 4x4's Avatar
...."Scary Larry"....
Old 08-08-2007, 07:33 PM
Rob C's Avatar
All true, and both can read dtc codes, the smarty can also adjust for tire/speedo, and with the Torque management, the smart accomplishes that through the four choices of stock, mild, moderate and wild when selecting your downloads. The smarty is more "tunable" then the bully because you ca choose the software based on turbos, injectors and trannys, and I have ran both and choose the smarty for me. In the end, its really what you want and need from the truck.
Old 08-08-2007, 07:36 PM
973604x4's Avatar
Bullydog also re-calibrates for speedometer these days
but you are correct, the bottom line is what you want and need for your application
Old 08-08-2007, 08:09 PM
RJOS's Avatar
Dont forget the PMT...With it you get the tunes, guages, nos and meth control, two pyro points(twins!!) saftey measures...Not a bad deal.
Old 08-08-2007, 08:27 PM
Jim Dynomite's Avatar
Is a scared rabbit faster than a raped ape? (hope I don't get in trouble for that one )
Prolly the same difference as Smarty and Triple Dog.
Keep what ya got, and make sure you get a boost fooler
.......Jim
Quick Reply: Trpple dog crazy larry or Smarty?
