Triple dog stack?
Quadzilla XZT stacks well....
Quadzilla Race module stacks but is pretty powerful....(can break stuff)
any boost fooling pressure box is a good stack.....(EZ, MP8, or a pressure only XZT)
those are common stacks...
extreme guys stack the TST with the bullydog...but like i said, its extreme!
Depending on what you have done, I was running the edge juice (regular not hot) with my bd (not crazy larry). Worked good, but not as smooth as the predator, hot juice combo.
Kevin
Kevin
I'll be stacking my Quad Std. module with my Triple Dog. I expect to run the Bully Dog on Extreme with the Quad module on the 30 h.p. setting. I may have to tone it down a bit so I don't break anything.
When towing I want to run the Quad on the 60 h.p. setting with the Bully Dog on stock or maybe Tow/Economy. I like the way the Quad box tows way better than the Bully Dog.
i plan to stack my ts mp-8 w/ a triple dog. i called ts performance and recommend it over the tst mp-8 stack wich is very popular. they said it delivers alot smoother power with lower egts...
yea they told me the same thing...they also told me to crank the MP8 to 100% and GO. i did it once and threw codes and the truck stumbled. I had other MP8 issues as well. TS reprogrammed them (yes apparently i had 2 bad MP8's) and i sold them. They are both doing fine now, though.
The BDDL-MP-8 GREAT STACK! 973604x4 sorry about your luck sounds like mine on the TST GONE! NEVER AGAIN!
Dont crank the MP-8! Just set halfway you will be good.
Then run the CRAZYLARY you will be REAL GOOD!
I run the ez, with the tq management off and the low end fueling on the edge makes it extremly tricky to drive(well drive nice anyways). I some times find myself chirping tires around corners when im not trying to but it sure is fun when you punch it.
Thats what i am running with my Scary Larry...and love it.
I want to try the EZ stack....i have one but its loaned out to a friend right now. I want it back!!! Do you get overboost codes with the EZ? I did when i tried it before pre-scary larry. XZT doesn't throw overboost codes.
https://www.dieseltruckresource.com/...95#post1353895
yea i think i'll need to stack a Quadzilla Boost Fooler if i use my EZ. thanks for the info.
I am running my Edge EZ with my TripleDog and love it. The power is very smooth but pulls very strong when you stick your foot in it. Also noticed a small EGT drop and mileage increase with daily cruising. Running the Edge on the 1st power level most of the time with the TripleDog on Tow/Economy. Put the Edge on the 3rd power level and stick your foot in it....nothing but smiles!
white250005
10-25-2007 10:19 PM
diggity dodge
19
07-01-2007 04:45 PM
duranator06
03-08-2007 07:27 PM
calfroper
03-06-2007 11:56 PM
gollnickdog
12-11-2006 08:34 AM
