Trimming Fenders
Trimming Fenders
Ok so I have a 2.5 inch leveling kit. I was wanting to go with the helo maxx 8's 20X10 which have around 5inches of backspacing. And I wanna do prolly the mickey thompson baja atz's 35X13.50's. I have some friends around here that run them and they seem to like em and I like the looks. Anyways I know im gonna have to trim some stuff.. mY question is what is the best way to go about this and how much will i need to remove?? Anyone with pics?? before and after would b awesome or just after.. Thanks
I really should've taken better pictures, but was more concerned about getting the job done at the time. I've got 3" lift in front, and 17x9 wheels with 5.71" backspacing. When I mounted the 37 x 13.50 Toyo MTs, I couldn't turn at all without major interference.
So, after a couple hours with a cut-rock, little sledge hammer, paint, heat gun and plastic welding kit for the fender flares, I have clearance with full articulation.
This is a picture of the other side, that kindof gives you an indication of how much I cut the fender, and rolled it back...probably 1 1/2 - 2".
--Eric
--Eric
Basically a very hot heat gun and a plastic filler rod.
Here are some on ebay-http://motors.shop.ebay.com/items/pl...asticQ20welder
Tell me more about this plastic welding kit?
It's a little tricky at first to make sure you're getting good penetration of the base material, but not too bad. It was my first time, and you can't even tell they've been modded if you didn't know.
--Eric
AkitaSumo
06-01-2009 12:28 PM
griffy
59
03-24-2008 09:29 AM
LOGAN
Off Road / 4x4
09-01-2007 01:07 AM
nfsommer
10-03-2006 11:40 AM
