Trans temp guage, tap where?
Heard mixed feelings on it, some say hot line to cooler, others say test port on the side of the tranny...
Not going to bother with the pan, since its after the fluid is much cooler...
Test port was said to be an average, but the high temp line will give the hotest to make sure it doesnt get too hot while towing.
Just wondering if I should get the diesel manor line($65), or the one at geno's that splices into the rubber line of the stock hose($10)
Just want to make sure I dont have any leaks to mess with...
uh oh. i have mine in the pan. didnt know that was bad. I was told keep it below engine temp and im fine. I have only seen over 180 degrees twice. usually i cruise 150 or 165 with it in the pan
I'll be putting mine in the test port because that's where the Commander calls for it.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
bgilbert
03-02-2006 04:01 PM
