Tranny guage sender wont fit into test port
I have the Isspro guage and sender. I read on somewhere that you could thread the sender into the governor test port on the pass. side of the trans. The sender and port are both 1/8" pipe, but the sender is too deep too thread onto the port. Anybody ran into this?
That's a common problem with using the test ports, along with it can contact almost anything moving inside. You have to use a 1/8 inch nipple, then a 1/8 inch to 1/4 inch adapter, 1/4 nipple, then another 1/4 inch to 1/8 inch adapter then screw in the temp gauge. I opted to mount it in the hot line for about the same price it cost to buy all those brass fittings.
studio5o
08-30-2011 01:16 PM
snowmanx
06-06-2010 01:53 PM
QWKRTNU
09-26-2006 10:22 PM
