tq managment
If you have a stock, or close to stock transmission itll slow you down into the breakdown lane. The tq managment comes on the trucks from the factory, its DC solution to their junk trannies, it cuts power untill you get going.
Right..and Bullydog lets you take the torque management off. What acook is telling you is don't do it if your transmission is stock as it is hard on them. If torque management is removed you have much stronger bottom end power but your drive train may not handle it for long.
torque management BDDL
Like Luken said, don't take the torque Management off. I would also not take it off, even if you have a good trans. The only exception, is when you are at the track. What it does when you take it off is, it stops the engine from de-fueling
between shifts, and is hard on trannies. Normal driving and road rages, you should leave it on. IMHO. The same goes for the low end throttle/torque option
and best used when racing at track.
I'm Kind Of Lost... I Just Set It Back To Stock Then Re Up The Bully And Turned On The Low End But Left The Tq Managment Off...
And Now It Seems The Tranny Slips Into Third......
So I Shoule Leave The Tq Managment On??
i wouldnt even put the low end option on a stock tranny, besides i know my truck drove like crap after i put the low end on, very eratic, and the turbo barked at me more then a ****** off shitsu
Your not understanding this. Your truck, and all other dodges have a feature called TQ management, just like they have the 48RE tranny. So with the bullydog you can remove the tq management your truck has on it, but thats a bad idea. You can also turn a setting on that will give it low end power, thats not such a good idea on a stock tranny either. Probaby why your sliping in 3rd
tq management
so just to be clear, the tq management is always on unless you turn it off? but does the tq management only applies to trucks with the autos, correct?
Don't screw with the BDDL torque management!!
Acook, you have a lot more patience then me on these treads....
Bob Wagner, you always have a "smarty" answer... One of these days I'll have to try one.
