Toyo MT's and better keep your eye on the road!
Man these Toyo MT's make the truck pull to the right. I thought it was my truck, lift and or alignment, but everything is good. I guess it is a problem with these tires.
I have been hearing the exact opposite. Most people are saying they are the best tire you can buy right now. Be sure you check air pressure in each as well.
Based on my experience, the Toyo MT's are the best mud tires I've ever purchased. Track dead straight and are easy to balance. Quiet, too, as long as you keep them rotated.
You may have a radial pull. As stated previously, swap the fronts side to side and see if there's a change...
had the 35's on my 03 they did the same thing cept mine pulled to the right. i swapped them around and it pulled to the left... after bout 2-3k it got way better, don't know why, guess they smoothed out a little. they are good tires though. good luck.
toyos
if you swap them side to side and it pull the other direction take them back a puller tire is a defect and the retailer should replace it. if it doent change swap the rears i have seen a rear tire to the same.
I've had three pairs of Toyo MT's never had any problems with pulling to either side. Like said above check air pressure and maybe balancing and alignment, my opinion they are the best MT tire on the market, I hope you have better luck with yours.
If they pull you generally have to stagger the caster to get them to drive straight. They get better as they wear in a bit.
Thanks, I'll play around with them a bit. Tire pressure and alignment are fine. The roads are fairly crownd around here. I am having to keep the wheel turned to the left a bit, more often then I think I should..
What size are the Toyos ,and what size were the tires (stock?)you replaced ?
Toyos typically run wider than most , and the wider the tire , the more likely they are to pull to one side.
