Tone Ring modification on an Auto - please help
Old 10-19-2005 | 08:44 PM
Nash's Avatar
So... I spent the last couple days reading about the tone ring modification. I would love to do this mod, I was under my truck changing the oil this afternoon and wanted to "do-it". I can't get the bolts loose, the motor just turns over.
I tried the tap the long ratchet trick, tried the 2 lb hammer trick & tried it with the belt still on the motor - no dice.
Any further tricks that I missed in the searches I ran and the last 90 minutes of reading?
TIA for the help!
Old 10-19-2005 | 08:49 PM
kelley15's Avatar
I wacked mine with the palm of my hand. Got it to come off that way. It wasnt easy.
Old 10-19-2005 | 09:00 PM
Dodgezilla's Avatar
I left the belt on and smacked the bolts hard about three times. The first two times it feels like you're just turning the motor over but the third hit breaks them loose. I don't think a regular hammer will work. Make sure you are hitting the bolts the right way too!
Old 10-19-2005 | 11:55 PM
Big Bob's Avatar
Take a big screw driver and put it on the crank sensor housing mount with the tip of it into the teeth of the tone ring, then use your ratchet and remove the bolts. Putting the bolts back in, I just used a 3# hammer and smacked a long ratchet or breaker bar handle about 3 times each.
Old 10-20-2005 | 04:43 AM
Dodgezilla's Avatar
Gee BigBob, we used the same "Torque wrench" to put ours back on!! The sad thing is that I have a brand new torque wrench in the tool box.......
Old 10-20-2005 | 12:11 PM
GTX's Avatar
GTX
I removed the inspection cover under the torque convertor and wedged a pry bar between the starter ring teeth and trans body. Did not damage any of the teeth. Did the reverse to tighten the bolts.
Old 10-20-2005 | 03:17 PM
4x4not's Avatar
Or you coulda got a real transmission!
Old 10-20-2005 | 09:28 PM
ROCKHEAD's Avatar
Just used two ratchets to do mine.
Old 10-20-2005 | 10:54 PM
Nash's Avatar
All good suggestions!
GTX - could you give me a description of where the inspection cover is?
Thank you all!!
Old 10-21-2005 | 12:20 AM
gatf4's Avatar
I used the GTX method. The inspection cover is right behind the oil pan and covers the torque convertor. I think it has 3-4 8mm bolts holding it on. I definately would not want to pry against the crank sensor or tone ring JMHO.
Old 10-21-2005 | 03:03 AM
Hounddog's Avatar
Wow.I could see a tooth breaking off that tone ring.Talk about a problem then.I bet its a Special order part !
Bobs rammin CTD
14
12-11-2007 12:38 AM
lawnmaniac883
12-26-2006 11:15 PM
mjsandt
06-03-2006 12:25 AM
HaulinBut
05-12-2006 03:06 PM
Dhackett
11-27-2005 09:36 AM
Quick Reply: Tone Ring modification on an Auto - please help
