tone ring mod & bully dog
Old 01-08-2006 | 05:43 PM
jb903's Avatar
i have an 05 auto with the bully dog can i do the tone ring or rokk tech mod wih the bully dog and will it work well with it. also how do i find rokk techs website? thanks
Old 01-08-2006 | 07:34 PM
Leadfoot's Avatar
I have been reading this and a few other forums and my info. gathered is that it depends on the truck. Some trucks have rattled with the tone ring and no other mods. Some are running the tone ring mod. Rokktech and a programmer or chip which effects timing. I personnaly have done the tone ring and waiting for my BDDL to get back from being updated with a new flash. If my truck rattles with both I will just loosen the dampner bolts and set the tone ring back to stock. Putting the tone ring back to stock is very easy, if for some reason your truck rattles. Good luck.
Old 01-08-2006 | 10:51 PM
Luvnacumns's Avatar
Tone Rig Mod and BDDL
I have done the Rokkteck sensor and had the quad zxt box stacked with the BDDL On Performance and had no problems. I am getting 20-22 mpg hand calculated.
Old 01-09-2006 | 12:13 AM
043500QC's Avatar
I run my BDPP downloader on Performance setting (90hp) all the time and have the tone ring cranked. No problems here other than the ocasional clatter on cold start-ups.
Old 05-06-2006 | 12:45 AM
J Banning's Avatar
Did you see an increase in MPG when you did the tone ring mod on top of the BDPP? I'm looking to do the same.
Is there anything wrong with having cold start clatter? (newbie question)
Thanks.
Old 05-06-2006 | 03:44 PM
Robert P's Avatar
works great on mine
Old 05-08-2006 | 01:32 PM
043500QC's Avatar
Thanks.
Yes, I do get a MPG increase when I can keep my foot out of it. As for the cold start clatter, I don`t think its because of too much timing. I moved the tone wheel back to stock and it didn`t change the clatter. There are several threads here and on TDR about checking your valve clearance. I checked mine and it was out along with everyone else. After I adjusted mine and brought all the valves within spec and all matched, my clatter was all but gone.
Old 05-09-2006 | 05:58 AM
dieselfumes57's Avatar
what the heck is a tone ring
Old 05-09-2006 | 11:17 AM
043500QC's Avatar
Use the search function, you`ll find all the info you ever wanted to know on the tone ring.
Buffalo
11-28-2005 04:53 AM
Big Bob
11-08-2005 01:41 AM
Dodgezilla
09-30-2005 01:56 PM
Mark Hodowanec
09-29-2005 10:15 PM
BossHogg
09-14-2005 10:48 AM
