View Poll Results: Which setting would you prefer?
keep it the same
![](https://www.dieseltruckresource.com/forums/images/polls/bar2-l.gif)
![](https://www.dieseltruckresource.com/forums/images/polls/bar2.gif)
![](https://www.dieseltruckresource.com/forums/images/polls/bar2-r.gif)
![](https://www.dieseltruckresource.com/forums/clear.gif)
20.00%
change to 0-4 being lowest to highest on timing
![](https://www.dieseltruckresource.com/forums/images/polls/bar3-l.gif)
![](https://www.dieseltruckresource.com/forums/images/polls/bar3.gif)
![](https://www.dieseltruckresource.com/forums/images/polls/bar3-r.gif)
80.00%
Voters: 15. You may not vote on this poll
Tnt / Tnt-r Settings
Taking a poll,
who wants to keep the timing settings the same and who would like to see them changed to this?
#0 lowest timing [nos]
#4 highest timing advance
I think it would be easier, if you have too much rattle, lower it one number.
Not complaining, but there seems to be a lot of confusion about this and IMO would make it a little more user friendly.
Taking a poll,
Quite a while back I suggested this and Marco gave a reply as to why he couldn't do it that way. I don't remember what he said - partly because I didn't even understand it. But I agree, sequential settings would be MUCH easier to deal with. You could actually remember that instead of having to read the sheet to figure out what number to set it on. Right now I'm wishing the TNT had a higher timing setting than it does.
I don't know why he could not do it that way. When there's a will there's a way.[ i hope]
The timing thing is counter intuitive for sure.
When I first got the TNT(R) I quite literally tightened the last bolts (new injectors and turbos) and drove to a dyno event.
I loaded level 9, cranked all of the settings, and set the timing to level 4.....Not surprisingly the truck ran like crap!
It wasn't until I started playing with the settings that I found out what was wrong....Ooops!
Screwing up the valve lash didn't help iether....Sooo maybe intuitive doesn't have anything to do with it!![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
omaharam,
Just curious, but you are finding you need more timing than level 0 and odd numbered SWs?
omaharam,
Gosh guys it's not that hard to remember/figure out. I've switched settings about 5 times now and I could do it in my sleep.
Your obviously smart enough to earn enough $$$ to afford this truck, I think with practice you can figure it out.![roll](https://www.dieseltruckresource.com/forums/images/smilies/roll.gif)
This hasent even been out a day, give it time.
I get max performance with my mods. Stock clutch still holding strong and hasent slipped. I know some may call BS but its all how you drive it. Wait for the turbo to spool and then roll into it.
sw#9 (sw8 had less rattle but way slower)
tq 3
timing 3 (2 rattled too much and sw#8 default is 1)
rp 2
tq 3
rp 2
tq 3
rp 2
tq 3
rp 2
timing 3 are for hugh injectors
you have stock?
chris
tq 3
rp 2
tq 3
rp 2
By the way your clutch is on borrowed time, I know you can drive around with 1235hp on a stock tranny but what fun is that.
If I'm going to have to be smart, I'm never going to be able to use this TNT stuff!!
Brian, Be happy the D@mn thing works on your truck!!!! It could be worse.
![EEK!](https://www.dieseltruckresource.com/forums/images/smilies/eek.gif)
Yes it is for for aftermarket injectors that gives you LESS timing and since I was getting too much timing rattle on #2 and #1 wasnt enough power I tried #3 and it's pulls just as hard as #2 w/o rattle.
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Guys that had timing rattle with the Smarty have been running the aftermarket injector program since it was introduced a year ago even if they didnt have injectors.
Every truck is different, you have to try and see what works best for you.
SMKHZRD
02-23-2010 09:46 PM
gdh11
08-28-2008 03:19 PM
kruegerlouie
14
07-25-2008 11:07 PM
Dwitt0187
14
05-18-2008 11:14 AM
jgiachino
05-12-2008 02:06 AM
