tnt race first timer what settings
just drove tnt race for first time-WOW!!, but im not sure where to set all the
sub levels, initially i set it on level 5 still got up to 1550* egts, thinking i should go down to level 3? im pullin the truck for the first time tomarrow night
but i wont have time to get it on a dyno befor then so im askin for a little help on the starting point settings,my mods are in my sig,. thanks guys
For just pullin I would run this combo
Torque Man #4
Timing #3
Rail pres #4 ( just for pullin )
Then since your only at WOT for a short time pullin id try level 5 atleast
Brett
Torque Man #4
Timing #3
Brett
He already has an MP8, smallish sticks, and a stage 3 CP3.. I don't know that I would run the rail at 4 with the MP8 on. Do you have a rail gauge? Watch is closely if you do.
do you have the wastegate turned off?
if your toasty on level 3, then it sounds like you dont have enough turbo... level 3 shuld be about the same as level 9 on revo and all the other programs. level 1 is only about a 100 hp program.....
pull
ryan lohman talked me int at last running level 5,solverodo thanks for the bump on that,good thing i never looked at tha pyro thank god. 18 trucks 5 dodges lots of chevys, took first by 26 feet thanks for the help guys, ill post a vid when i get a chance.
![guitarist](https://www.dieseltruckresource.com/forums/images/smilies/guitarist.gif)
pulled level 5,tm4,rp3-mp8 at 75% im sure it stayed over 25k but not over 28k,wg-off,shift df off-but had no gear indicators-is this normal when thats turned off. when i pulled down and unlocked the tc it shifted down to 2nd but then popped into neutral,kinda scared me it took a few sec to come off high idle! courious how much farther id pulled if it stayed in gear!
![Wink](https://www.dieseltruckresource.com/forums/images/icons/icon12.gif)
well, std tnt pulls hard on my truck to 3600 rpm, -r still isnt letting up at 4k..... id guess with the right settings... yes....
i know ya got me by 3 hp.... or do you?
![TapedShut](https://www.dieseltruckresource.com/forums/images/smilies/new1/tapedshut.gif)
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
SMKHZRD
02-23-2010 09:46 PM
gdh11
08-28-2008 03:19 PM
Dwitt0187
14
05-18-2008 11:14 AM
jgiachino
05-12-2008 02:06 AM
TORQUE BEAST
13
05-09-2008 02:31 PM
