Tnt/r?
Tnt/r?
Just got the TNT/RThank you Bob!Im sure this has been answered several times on other threads but are the timing,torque and rp adjustments the same as the TNT non-r?And just to make sure I'm straight,timing 2 is the most timing? Timing from most to least is 2,1,3,4?
I am jealous Homewrecker! I have asked for it a couple times. I have yet to get CP3 upgrades or injectors, but the idea is scratching at the inside of my skull.
Did you run the regular TNT for a while?
Been running the TNT since it was released.Using it for all duties,grocery getting,racing and towing.Has took a while to find the settings that work best for the different driving conditions but pretty much have it figured out.
Thats just like the answers I've got in the past."I think","maybe" ,not here's the answer.Not ******* on you man.Seems to be alot of people confused on this.I wish Bob or Marco would just chime in on this.
DTR 1st Sergeant
Oh, boy-- see below pasted from MADS website:
For regular REVO:
Injection Timing:
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors ( less timing advance than # 2 )
# 4 - for fuel economy ( more timing advance than level # 2 )
Important! The odd numbered SW's ( 1,3,5,7 & 9 ) use the advanced timing and the even numbered SW's ( 2,4,6 & 8 ) use the stock
timing.
This is only true if you don't adjust the options! With the Revo you can choose ANY timing you want, no matter if the Catcher you'll
download is odd or even! You CAN, add timing to the software's that have none, or use the stock timing in the odd # ones. Your
pleasure.... By definition for all adjustable options the default is # 2. EXCEPT for the timing. The timing has two defaults. # 1 for the
even numbered SW's ( stock timing ) # 2 for the odd numbered SW ( advanced timing ). To avoid confusion and to help the customer
in returning all levels to default ( if need be ), key # 0 is used to return Smarty back to the default levels. This is most important for
the timing. When Smarty is set back to default with key # 0, the even numbered software's will use the stock timing and the odd
numbered ones the advanced timing.
FOR TNT ONLY:
Injection Timing:
# 0 - Default
# 1 - Stock
# 2 - for aftermarket injectors
# 3 - for Hugh aftermarket Injectors ( less timing advance than # 2 )
# 4 – for use with NOs ( less timing advance than level # 3 )
The odd numbered SW's ( 1,3,5,7 & 9 ) use the advanced timing and the even numbered SW's ( 2,4,6 & 8 ) use the stock timing.
This is only true if you do not adjust the options! With the Revo you can choose ANY timing you want, no matter if the Catcher you'll
The injection timing is critical for the engine responsiveness and overall performance. The difference between one timing level and
the next one can be as much as 85Hp! Which is the right one? That depends upon the mods done to the engine.... The only valid
way to find out is a dyno. Boost pressure readings “per se” just don't do the trick. A more advanced timing will typically produce
less boost than a more retarded one but that does not mean that the more advanced timing provides less power.
That should clear things up....
For regular REVO:
Injection Timing:
# 0 - Default
# 1 - Stock
timing.
FOR TNT ONLY:
Injection Timing:
# 0 - Default
# 1 - Stock
I have read that before.Call me stupid or whatever but its still not crystal clear.I guess I'm used to old Smarty tunes where aftermarket inj. was less timing.Now it appears to be the most timing.But what is next.Is it 1 stock or 3 huge AM inj?Just spell it out for me.Whats the order? 2,1,3,4 from most to least.Does the TNT/R follow this same pattern?
While not definitive this is the way I see the words from MADS.
If you select default which is #0 then the odd sw's will be the same as #2 aftermarket injector, but the even sw's will be #1 stock timing.
If you select #1-#4 then both the odd and even sw's will be that timing.
Now the question I don't know the answer to: is aftermarket injector less timing advance than stock, or more? I would think more. But number wise that puts it out of order. As I read it, aftermarket injector is the most timing advance TNT offers, or is it?
