Tnt ?
I put the TNT in this afternoon. SW-7 TQ-2 TM-2 RP-2 & Ran it for a few minutes. Seems pretty close to 4.4, but not quite. I may bring the TQ up to 3, & play with TM-3 , on SW-9 & see what happens tomorow. For some reason my truck with the HTT 62/13ss/65 needs less timeing to build proper boost. Don't know why, but on default timeing on both 4.11, & TNT I have trouble hitting anything over 39-40#. On 4.4 I hit 42# easy.
I called HTT about a month ago about my boos on 4.11 aftermarket turbo & they said the 4.11 had the timeing too high. I ran the aftermarket inj/turbo for a little while & it was better, but 4.4 realy did the trick. I think I'll try TM-3 & see what it does.
I did some seat of the pants testing today, & I got TNT SW9,TQ3,TM2,RP2,WG-off to get real close to what 4.4 felt like. Only got to 41#boost, but very little smoke, & pulled hard as far as I could get it where I was. I don't know what my RP was, but I'll run it here & see if I can get my RP gauge in soon, & find out.
Bob. No, I haven't had the turbo off the engine. It was installed right out of the box. I'm assuming that it's set @ 40-42#. HTT also told me the same when I called them when I was runnig 4.11 Aft-Turbo, & could only get 38# out of it. When I was running 4.4 I could hit 42#, & it would get there before 2800 rps, & hold there. With any of the newer software, I have trouble getting 0ver 38#. With the settings I'm running now, I can hit 41.3#, which is pretty close. It takes a bit to get it there thoe. Thats on Sw9,Time-2, RP-2 WG off. I'm considering turning the Time up to 3. But the truck runs prety well as is now. Any advice about the timeing?
Put 100 miles on TNT today. I was able to hit 42# briefly in O/D but had to back out. Normal WOT boost is still 38# but the truck flies. Very little black smoke once the turbo spools. I'd still like to get my 42+# boost back, but as it is now it runs as good as 4.4 I think.
TNT Sw-9/TQ-3/Time-2/RP-2/WG-off
Thanx.
I'd say go for it. I don't know what your boost levels are with your turbo. My truck doesn't like the advanced timeing, but it's ajustable. Give it a whirl. Takes 1/2 the time to down load too. Just save 4.4 to the HD so you don't lose it.
