tire size
tire size
Ok i know this has been brought up before, but did a search and really could not find my answer. I am looking for a set of tires. i would like to know what is the biggest tire i can go with on a stock truck with stock rims dont want to put a lift on just yet. looking at an aggressive at and mts. What kind of tires are you running and whats the tread life? thanks
Yep, this has been neat to death and a search will bring up all the threads.
35".
Go too wide and you'll flirt with death wobble. Go too wide and you may rub a bit at full lock. What's too wide? 305 is about the limit. Wider can cause some trouble.
35".
Nitto TerraGrapplers 305/70/17 on mine. No lift, no level and no rub. So far about 25k miles on them, with rotating every 3k miles I hope to get another 25k on them. I am pretty sure you could go to a 315 and still be alright but after that you will need at least a level kit.
hey thanks a lot guys this helps from what i have been seeing on fitment guides is anything over 33's i would need a 2'' leveling kit. i here alot of good and bad about the nitto's but am considering
them
them
I've seen Toyo and Nitto 315/70/R17 act the same as the BFG, which makes sense as they've got a slightly narrower carcass with a wider tread, and General A/Ts (and of course the Bridgestone Duelers) act like the Firestones, with a slightly wider carcass and slightly smaller tread width.
I put BFG 315-70-17 on my 2006 when it was new, not a problem. Wore that set of tires out right at 50K, now on my 2nd set. I added the KORE leveling kit, but that had nothing to do with tire rubs or any problems, just wanted it level.
CD
CD
schoust
10-21-2009 10:09 AM
bigdogtruck
18
11-21-2007 08:09 PM
4RnrRick
02-27-2007 11:25 AM
