tips for cam install
Am going to install my helix 2 over this nice 120 for thanksgiving, and i was woundering if the salty dogs on here that have done it before have any tips or tricks.
thanks all.
semper gumby
thanks all.
semper gumby
I went to a dodge dealer and had them print off the R&I pages from there manel and they let me use the cummins tools (chop sticks-fishing rod) for the install .
and if your putting in new lifters make sure the block of motor is leavel makes fishing the lifters easyer.
http://www.relentlessdiesel.com/foru...c.php?f=2&t=14
http://turbodieselregister.com/forum...m-install.html
http://www.turbodieselregister.com/f...-gen-pics.html
some very helpful info...
I read through everything i could before i did my swap.
Some tips...find the tool to remove the fan clutch properly....i spent 30 mins with a large adjustable wrench and a prybar....busted the hell out of my knuckles...but got it off. Also I just loosened my power steering pump so it was out of the way of the front cover rather than removing it or it's pulley. I was able to snake the pushrods and dowels in and out of the rear two cylinders with just the rubber plugs in the cowl removed. I did not have to remove the wipers or anything. I removed my front bumper first for ease...it was 4 bolts and i was able to uninstall and install it by myself...it made working on the engine much easier.
IF i remember any other tips i will chime back in.
Get a new oil seal for the front timing cover, or it will probably leak from then on.
Overall, it's not that bad...just take your time and have fun!
I second the fan wrench suggestion ^^^.
I'll PM you my phone number...call me if you run into anything or have questions. I just finished my install last week.
--Eric
--Eric
etn550
04-01-2010 12:12 PM
Teddy Bear
03-24-2007 06:10 PM
judge88
32
12-19-2006 04:15 PM
