Tip for Amsoil BMK-11 Bypass Installation
Old 03-05-2007 | 08:17 PM
FirstDodge's Avatar
Lightbulb Tip for Amsoil BMK-11 Bypass Installation
Well . . . I installed my Amsoil bypass system about 2K miles ago. Ever since I installed it, I have heard a rattle sound around 1200-1400rpm's. VERY annoying. I mounted the filter on the firewall (pic in gallery) and thought it was vibrating there . . . NOT. Long story short, after checking many things, I found out it was the harmonic sound of the oil going through the inlet line. If you are installing the BMK-11 system, make sure your input line from the full flow filter is not 14" long, but at least 18" long. As soon as I lengthened the line, the noise stopped.
It's just one of those freak things, but if this post can save one person the aggrevation that I went through, then it is worth it.
Old 03-05-2007 | 08:47 PM
53 willys's Avatar
that's weird that 4" worth of tubing would make a difference?
Old 03-06-2007 | 05:09 PM
FirstDodge's Avatar
Yes i know . . . the strangest thing. The pulse of the oil pump at that rpm what that length of hose makes a metal to metal sound. I know it sounds crazy, but when I lengthend the hose 4", the noise went away. I used the exact same connectors and everything. Probably a one in a millon problem, but it happend to me
My friend got in the truck and the first thing he said when he heard it was "it's a hydrolic noise". It's oil going through a line. I couldn't believe it.
Old 03-06-2007 | 07:07 PM
Obben's Avatar
You probably hit the resonancefreq. for the hose dimension and the specific media runnin through... hehe
Old 03-08-2007 | 02:08 PM
PhotonPhixer's Avatar
Good job, FirstDodge. Glad we got rid of the noise. It sounded like a little mad hornet in your dash.
Old 03-08-2007 | 02:18 PM
Cowboy_Customs's Avatar
Now how did you get the notion to lenghten the hose in an effort to eliminate the sound? (maybe i missed a previous post on this issue)
I'll go back to the 1st gen forum now.
Old 03-08-2007 | 05:31 PM
rjm022's Avatar
no problems here. it has been flawless.
https://www.dieseltruckresource.com/...ghlight=bmk-11
Old 03-09-2007 | 07:29 PM
FirstDodge's Avatar
Obben hit it on the head. It is about the resonence frequency. The oil resonates at a certian frequency in that diameter hose. If the hose is longer or shorter, it will change the point where it resonates. I couldn't go shorter because it wouldn't reach the filter, so I had to go longer. Another option would have been to go to a larger diameter hose. Obben or PhotonPhixer can do a better job explaining it. Now that the hose is 4" longer, it hasn't made the sound once.
kprc51
12-31-2007 01:54 PM
Arkapigdiesel
32
08-21-2007 09:00 PM
FirstDodge
18
12-10-2006 08:30 PM
rjm022
10-02-2006 04:59 AM
dogger
11-16-2004 08:24 AM
