Timing/Duration Boxs and Pressure Boxs!!??
None of them will add boost, boost is a byproduct of load. You need a boost fooler so that the ecm wont give you a check engine light. What a boost fooler doest is tell the engine that it is getting a maximum of 32 psi or whatever that model should have, while it is actually getting say 40 or whatever. To get extra boost, means extra fuel. When I run my setup with the edge on 1 I will only get 44psi, on 5 55 psi.
The diablosport predator is a great unit, but it wont do any boost fooling for you. The edge juice will
Kevin
Kevin
Morkable- thats true. My statement would have been more accurate if i said "Edge Juice will add boost on anything with the settings turned up."
Kevin
Kevin
This will keep peak egt's down while towing or hauling something or even on WOT runs empty.
The all do some duration but it is a pretty small amount. You are correct in that I do not really like duration only because of the technical difficulties it can cause. Most of this is related to driving the injectors directly though. We do it some through indirect signal modification and it helps on the bottom end. That is why they run so good down low.
i edited the original list
Just bought an 06 and found a lot of threads about this topic. I would think advance in timing and duration would be safer than pressure? Is that correct? I would first like to add an exhaust, intake and then go to a programmer. I have an 06 auto, so dont want to get crazy with HP?
the diablosport power puck raises rail pressure I believe when it is with the downloader in the "stack tune". an edge juice on my 05 would make about 34 psi of boost from what I can remember. that was not a hot version on a stock turbo truck at the time
t-boe
01-04-2007 08:35 AM
sdarchery
20
10-31-2006 08:39 PM
morkable
29
10-27-2006 07:31 PM
MonroeDiesel
03-30-2006 03:00 PM
Lrdchaos
02-07-2006 09:57 AM
