timing
timing
A buddy of mine asked me today if "all" timing is the same . I feel that that is a good question. He has a 24 valve, and was just wondering. So, to all knowing, is this the case? AKA, the comp box adds timing, the smarty "can" add timing, the hotrod vp44 adds timing. (Not certain what I did to highlite "smarty") or that stuff for that matter.?? But, regardless, how is one to run a hotrod pump with the comp box if both add timing? And is every manufactures timing rated differently?
Hey Quad, I've been talking to Roark at the quad shop about my reflash without the throttle pos. senser tap and timing off. I got it back...in awesome time I must say, great business, and now I cannot see over 30lbs of boost in crazy larry or performance, but tow I can and it seems to be a whole different truck like it used to. Low end unbelievable, buy without larry it doesnt have the top end. Have yall figured anything out on it? Thanks again for the great service
I am pretty sure it has nothing to do with us. We do the same thing regarless of what your PCM is programmed to. If it is working properly in tow mode, or with the BD off, I would call BD and tell them they are doing something really weird in their programming. Nothing I can do if they are doing something weird.
Thanks, but what I dont understand is before I sent it in to get the timing off and tps removed it was UNBELIEVABLE with the chip on. Now it doesnt even feel like it's on it. BD programs havnt changed and and the guy Roark Im talking to says a few people are having some of the same issues. And the whole calling BD thing...aint happenin. I've been tryin for over a month and even have a guys extension # and will end up listening to opera music for 20min. Yall answer within 1/2 ring and it is VERY NIce. Thanks
And actually better yet, you did not even get to test it, so we don't know if it worked or not?
Then, you sold it, without having a normal program put on it.
That is why he had to send it back.
It works decent on the tow. I've pushed hard in larry and performance but it gets too hot b/c of low boost. Roark said pretty much go to the old surging program or switch bd or sell the quad. Will it work great with the smarty?
You don't have to go with the older program, just the normal program. We have done this on a couple of trucks and for some reason it seems to work better than the stacking file with some of the Crazy Lary programs.
Anything you do will work great with the Smarty. They obviously have their tuning down a little better and it does not change from truck to truck, or minute to minute.
The only reason he needed to send it back is because we made a special file for your stack that did some very unusual stuff because you were having trouble over 50+ psi with some weird boost happening?
It wasn't just on my truck that i was having problems. that XZT was also extensively tested on an 06 truck...totally stock. It performed flawlessly. It was then tested on an 06 with a bullydog...and had roughly the same problems i had when it was on my truck with a Bullydog.
Quad I realize none of this is your fault and you were going over and beyond with what you were doing. I greatly appreciate it but I moved on. For the record, I have not found ANY pressure box that will consistently boost fool with my Bullydog. I have an anonymous boost fooler plugged in with my Dr. Performance box.
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
