Thuren Fox Steering Stabilizer
I had dual stabilizers, but had to remove the driver's side with the Mag-Hytec install. I had cut the factory passenger stabilizer mount when I installed the dual kit last year (dual brackets bolt to the bottom of the lower control arm frame). Now of course, it pushes to the left down the road. I want go with a great single as I don't think duals will work now.
So....can I still use the Thuren stabilizer using this bracket? It really just pushed the mount forward a few inches (slightly different angle). And...will it clear the diff cover? Any other suggestions welcomed....-Thanks
ptgarcia
41
08-22-2011 05:55 PM
N2Ram
07-26-2009 08:30 PM
mike moore
09-25-2008 07:14 AM
paroxysym
10-02-2007 12:06 PM
