Throttle response with TST PMCR
Old 10-29-2006, 10:45 AM
wap
wap's Avatar
emfc 22, the reason for runnin the lower settings is too much pressure
jvjump, I do the same as you, run tst on lower settings, and leave the mp8 off and only crank it when I need it.
I dont know that the mp8 adds THAT much more power put it flattens the curve a good bit makin the truck faster/quicker and more enjoyable to drive, even more so than the rail pressure option on the R49.
Old 10-29-2006, 03:35 PM
RamWheelsBy4's Avatar
I have an EZ stacked with my TST and was stacked with HOT Juice before that. Although I wish the EZ had more adjustability like the MP-8, it seems to be very good pressure only stack with TST. I can definitely tell the difference on the bottom end without the EZ. I usually leave the EZ on level 1 unless I am at the track. With the Smarty or BDTD added to the mix the EZ still seems to help on the very bottom end just enough.
Nascarcamper
01-01-2005 12:04 AM
Agades
11-02-2004 10:11 PM
Ttexas25
30
09-04-2004 05:08 PM
JKE
03-29-2004 06:45 AM
Quick Reply: Throttle response with TST PMCR
