Threw 2 codes.
Threw 2 codes.
Hit it good on the way to the house tonight and got
rail pressure sensor out of range
fuel rail pressure to high.
I've had the DIY CP3 mod for a while now and just did a 392 kit last sat. Truck has run great since then until today it doesn't want to start and now this. Both of my chips are set on level 2 and I 've never had a CEL before after 45k until now.
Seems like my FCA is sticking again because its surging bad. Think maybe that could be it? I'll take it apart tomorrow and try to smooth it out some more.
Pulled the fca out again today and polished the crap out of it. PUt it back together and still bad surging after taking it apart twice and turning it. Think its gone bad? Also got a P088 code again on the way home.
DTR's 'Go to Guy'
1. Fuel Pressure Sensor
Using the scan tool, compare the scan tool reading for fuel pressure set point to the scan tool reading for actual fuel pressure.
Does the actual fuel pressure correlate with the fuel pressure setpoint while operating the engine over various operating conditions?
Yes
Go To 2
No
Check the electrical connector of the Fuel Control Actuator, if the connection is tight, replace the fuel control actuator.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
2. FUEL PUMP
Turn the ignition on.
Disconnect the Electronic Fuel Control Actuator connector.
Connect an incandescent test light across the Fuel Control Actuator driver pin and the Fuel Control Actuator return wire at the fuel control actuator connector.
Observe the test light.
The ECM will perform a self test of the circuit which should momentarily flash the test light brightly, one time, approximately 20 seconds after being connected.
NOTE: Compare test light brightness to that of a direct connection to the battery.
Did the light flash brightly?
Yes
Replace the fuel pump.
No
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Yes
Go To 2
No
2. FUEL PUMP
Yes
No
DTR's 'Go to Guy'
That's is supposedly one of the tests for it!? If it clicks it is getting power. According to the symptoms, it sounds like a failed FCA, but if it clicks it should be working to.....? May be a bad sensor for rail pressure causing bad info to the ecm?
bigredBCS
12-05-2006 09:56 AM
