thoughts on this setup
I'm trying to eliminate spiked rail pressures. What are y'alls thoughts on running an Xzillaraider race module with 50hp DDP's? That should eliminate the rail pressures being to high. After thats installed looking at a turbo. Should be close to 500rwhp? A lift pump is on its way now. So that wont be an issue.
yeah, bigger sticks would be a way to limit r/p.
remember, when you drain the rail, and cause popping, you are creating rediclous cylinder temps, you wont see this on your pyro, and you will melt piston crowns.
thanks for the info. I have the lift pump on its way. And looking at the quad race. I really like the power the diablosport makes, but i really want the shift on the fly feature. And should give really good numbers with the ddp nozzles. I've seen alot of stacking 2 boxes, and adding a turbo to get over 500rwhp but I do wanna regulate rail pressure.
cliff-1972
0
10-13-2002 05:04 PM
