Thoughts on running a FASS & eliminating stock cannister filter
I thought I read a thread on this before but couldn't find it...
Just wondering if folks who are running the FASS are still running their stock cannister fuel filter?
I thought I read somewhere that with the FASS you could eliminate the the stock cannister filter... any thoughts... thanks...
Yes, I have done this. FASS eliminates the need for the stock filter entirely. FASS incorporates a 2-3micron fliter in the system depending on what you get. (95 or 150) The stock filter is 7-10 microns depending on whose filter you get. with FASS, you also get water separation and air separation as well.
My FASS 150/95 has been on for over 3 years and about 75k miles now. It completely bypasses the OEM filter and canister. I have had no problems so far. I run a 3 Micron rated Fleetguard filter and change it around 25k.
So, there is no need for the canister? Do you just take it out? I have mine set up and as far as I know when it was installed fuel still flows into it. Wonder if this effects the pressure and with out the canister more psi would get to the cp3. I think my canister is used as a return.
u need to but and eliminator plate for the return line you get is from somewhere like gdp has a nice one i have that one on my truck it makes the engine bay look alot better and its not so cramped on the left side of the engine bay.
danny
danny
So all you need is an eliminator plate for the return line? Once you do this then you can eliminate the canister? I hear some trucks throw the check endine light when they eliminate the canister, is this true? Anybody give me a link so I can look at and probably get the eliminator plate
http://www.glacierdieselpower.com/pr...x?pf_id=0306FE
this should work
this should work
the fass has a 2-3 micron filter in so it is going catch almost everything and if it is small enough to get through the 3 micron the 7-10 micron you have in the canister is giong to be doing nothing.
danny
danny
