Thinking about buying a commander
Old 10-31-2006 | 10:56 AM
stealman's Avatar
I have a manual trans and therefor do not need a trans guage, so I have read. I thought I read somewhere that the trans guage could be used for the rear diff. What do I need to get to do this? I am also going to go with the fuel pressure kit. Is that all that I need to buy the commander and additional fuel pressure kit?
Old 10-31-2006 | 11:28 AM
carcrz's Avatar
yup. One advantage to the Commander is that you can pick & choose which gauge you want displayed. You have the choice of 1, 2, 3, or 4 on the screen at the same time & can pick from all of the sensors you want displayed.
Old 10-31-2006 | 01:44 PM
welndmn's Avatar
Yes, you can make it an oil temp.
Because its a one wire sender, I'd be temped to put it on a switch and jump between different temps.
Old 10-31-2006 | 01:59 PM
dodgeboy59td's Avatar
Jus got mine installed yesterday and i do say its a nice setup! Install isnt to difficult, other than the rail pressure connection, quad if you see this you might want to add it to the directions, in the directions you say to connect it to the green wire on the harness to the box that you sell, and if you dont have that box then your kinda lost, but i found it online that it was the middle wire to connect to. Might simplify a few problems with future buyers. Other than that i like it!
Wes
Old 10-31-2006 | 02:10 PM
stealman's Avatar
I'm confused. What are people doing with the trans. temp who have the manual trans.?
Old 10-31-2006 | 11:50 PM
BigBlueDodge's Avatar
The Commander includes one probe that can be used for either tranmission temp or oil temp. I had a manual tranny so I used the probe to monitor oil temp.
Old 11-01-2006 | 07:35 AM
carcrz's Avatar
Wes
I second the nomination!
Old 11-01-2006 | 09:19 AM
josterbauer's Avatar
I was told to install the wire tap for the rail pressure to the center wire in the rail pressure connection. It works perfect on mine. Just install the wire tap to the center wire of the (3) wires.
Old 11-01-2006 | 10:11 AM
qzilla's Avatar
Just so you guys know you can actually plug the trans temp sender into anything you want. It just comes with stuff to go into the transmission or into a port on the oil filter housing to read oil temp.
Since it uses its own sensor you could literally just leave it in the cab and measure coffee temp if you wanted to!
Old 11-01-2006 | 10:39 AM
welndmn's Avatar
So I could mount it to a switch, get another probe and toggle between oil and tranny temp
Old 11-01-2006 | 12:46 PM
Duallydog's Avatar
Keep track of your own body temp with it.
Old 11-01-2006 | 06:13 PM
qzilla's Avatar
Yup, we can get you another probe and switch it anytime you want.
Old 11-02-2006 | 01:12 PM
spro2395's Avatar
Quad
Could you tap the wire and switch between trans and diff temp?
Thanks
Joe
morkable
11-21-2006 10:06 PM
stock03
11-10-2006 12:27 AM
PHX_ATC
21
01-29-2004 08:53 AM
Jack Thorpe
27
09-17-2003 10:46 AM
KevinR
12-05-2002 09:00 PM
