Tester needed for Commander & BD X-Power
Ok, the title pretty much sums it up.
I just need a single tester at this point. It is easiest and best if I can find someone that already has the Commander and X-Power and then I can send them the X-Power adapter kit and a USB update.
If not, all beta testing procedures are the same and if you have an X-Power and want a Commander to go with it for gauges, power levels changes, and de-fueling protection then sign up here!
If you have any questions please let me know.
First come first serve.
Quad
Quad
Same here. I'm indecisive whether I should get the Commander, or just a set of gauges. I've gad good luck with the Xzillaraider, and I doubt that I'll need the features of the Commander. But I definitely need gauges
I think you need a colder climate tester North of the border!! Really! I'll be a pig......er......beta tester.
I don't have either though.
Well, I really need someone that already has one and is familiar with it and how it performs. We want to make sure all 5 levels are working 100% properly and the defueling works as well.
The X-power has some unique things the owners can do with it by moving jumpers around and we want someone that is very familiar with the module to make sure we have our ducks in a row. I am 99.9% positive we do from our own testing but, it is always good to have an un-biased 2nd opinion.
Quad
Quad
I installed the x-power plus in last week, still playin with it, but I understand its concept.
04.5 Dodge 3500 Quad 4x4, Airaid, Autometer analog's, straight pipe, 4" lift on 33" M/TR's Black on Black with Bling
diesel j,
Do you care to beta test a Commander then that will control the X-Power?
If so shoot me a PM and we can make it happen quickly! I can also answer any questions about how beta testing works, although this will be a pretty cut and dry test and should be pretty easy.
I just notice that you have analog gauges, so know that you will either need to drill an additional hole in the manifold or you will need to remove the autometer TC and put ours in place.
qzilla
22
05-08-2007 05:45 PM
qzilla
04-21-2007 12:51 PM
qzilla
04-20-2007 01:18 PM
qzilla
04-13-2007 08:12 PM
stock03
11-09-2006 11:27 PM
