Tank Vent Mod
Old 01-27-2006, 07:38 PM
Dodgezilla's Avatar
I've never had that problem on this truck but I used to top off my 92 and it would always leave a puddle in the summer time until a drove a few miles...
Old 01-27-2006, 10:13 PM
smokey196240's Avatar
Ok dummy here i got my bed off right now replacing with costom bed i see the two barb fittings what do i do with them and does anyone have pics of this mod
Old 01-28-2006, 08:14 AM
tbone's Avatar
The tank is heavy folks so the less fuel in it, the better. I was able to get plenty of room under my 2wd by jacking the left rear only. You take the parts that David Kelley sends you, drill a hole in your fuel tank, install and seal the new fitting in the new hole. Then you connect the hose, plug the old hose, and reinstall the tank.
You can catch all of the tank material by pulling the lift pump/pickup out of the tank. That will give you room to insert a bowl to catch the pieces of tanks when you drill the hole.
This is a pic of the tank pre-modded. The new hole got drilled in the tall end of the tank.
Done and back in.
After this mod I can hold 40 gallons.
Old 01-28-2006, 11:43 AM
01350banshee's Avatar
Got mine waiting to be installed also. If it would STOP raining for at least 1 day on the weekend I could get it done.
Old 01-28-2006, 01:01 PM
tankeryanker's Avatar
Thanks tbone. I was thinking of doing this mode & was wondering how you kept the drill material from falling into the tank.
Old 01-28-2006, 09:59 PM
TNDODGE's Avatar
Yea, appreciate the info guys.
Old 01-29-2006, 02:52 AM
Help guys what are you guys doing to the two barbs on the top of the tank
Old 01-29-2006, 10:00 AM
I heard most are putting fuel line hose & connecting the two together, putting a T fitting in the middle & running another piece of hose to a filter that can still breathe air for the ventting of the tank.
Old 01-29-2006, 12:59 PM
NB64's Avatar
What ever you do do not overtighten the white nylon piece. IT WILL BREAK. Of course I broke mine on a Saturday. Dave Kelly was great, but it still took two days of no truck. No problems at all
Old 01-30-2006, 02:26 PM
cool now we conect the to vents into one breather and we put a new vent at the rear of tank at the highest point and run it to a breather also now how about the old vent hose going to the top of filler neck leave it or what ??
hate to beat a thred into the ground but want to do it right the mod that is .
Old 01-30-2006, 02:31 PM
RonP's Avatar
Smokey, it gets capped off with part of the kit. I just zip tied it to the new line attached to the vent by the filler. Remember, that is where the hose from the new vent runs to. the same location as the factory one. just did mine sat and I am so happy with it so far.
Old 02-21-2006, 04:18 AM
millco's Avatar
What I did with the vent:
I put the DKelly vent mod on my '05 last year and it always did great. Now I can't wait to get it on my '06. I could fill with the nozzle on full flow and still only have minumal foam at the end. Fuel standing in the 'pipe' in just a minute or two after the nozzle clicked off the first time! I never had an overflow problem; course I may have just never left it really full sitting on a hot day.
I ran my 1/4" vent hose up into the left front corner of the bed, just in front of the fill 'pipe'. That way I could fasten it up to the side of the bed pocket and attach the cheap plastic fuel filter up high.
[img]
http://i23.photobucket.com/albums/b3...VentFilter.jpg
[/img]
I found junk in the tank when I did the vent relocation. Some of it I think was from the open 'roll over' valves and I really think the rest was from the factory. What will we do with these guys????
Want to see another good one? Are you 'using' any coolant? Take a look at the $1 DC hose attached to the coolant recovery bottle. When you find the open end of it, look down to see a possible secondary storage area for your coolant. I put a vacuum cap on mine and drilled a pin hole in the lid.
My kids know better than to do what these guys did here and there........
Dan
pet05
63
01-10-2009 10:30 PM
welndmn
07-10-2007 07:51 AM
TPilaske
21
08-15-2006 01:56 PM
ramtd02
19
05-04-2006 10:17 PM
Brad02ctd
17
04-27-2006 12:28 PM
Quick Reply: Tank Vent Mod
