Super Singles
Super Singles
Anyone get a look at these yet. Makes me wish I had a duelly. I did a little math and figured you'd need 4.88 or 5.13 gears to get the engine back up to the same rpm as the 3.73's. (are 4.88's or 5.13's even available for the american axle 10.5 or 11.5?)
http://www.michelintruck.com/michelintruck/index.jsp
http://www.alcoa.com/alcoawheels/nor...asp?cat_id=893
Oh if I only had the money. If anyone outhere has these on, throw some pictures up. (They might be hard to steer if you put them on the front, hehehe. I know they're just for the back)
No, they are just high load tires as is. for a pick up, you don't need anything more than they can hold, unless you are putting more than 10,000 lbs on your rear axle. They might even come in more than load range H.
Registered
was wanting the supersingle because their wider than reg., and just run one on the back that's like 14" wide. We have a set of 22.5 SS on the rear of a spreader truck, no more rocks in the duals and it goes better than it did with duals
I am trying to have some custom 8-lug 22.5s made including a 14" rear wheel that I can put those super singles on. I will post pics when I am done.
Look around on line and be sure to ask alot of questions chrome wheel sells a lot of USED wheels that are hi speed polished! I know first hand He sold me a set of bad wheels and their customer service is sucks! Buyer beware
Check out e-bay they have brand New sets of Aloca Super Singles with the on/off road tires for like 4500.00
Jus Cruisin
11-20-2006 06:22 AM
