suggestions on a 4" lift?????
evidently, i have really admired jd dearden's dually. i like the 4" look with the 22.5's. can i get some suggestions on a good 4" lift system? not into keldermann air stuff. but want to upgrade to king shocks too! can't beat em.
thanks,
darren
thanks,
darren
Superlift products are warranted to be free from material and workmanship defects for as long as the original purchaser owns the vehicle that the Superlift product was originally installed on (proof of purchase is required). This warranty is non-transferable. Superlift's limit of liability under this warranty is to repair or replace the product at Superlift's option. Consequential costs such as, but not limited to labor fees, loss of use, loss of time or freight charges are not covered. Any product that has been abused, altered, incorrectly installed or used in competition is not covered. Product finish is excluded from this warranty. Items that are subject to wear are not considered defective when worn and are not covered. The warranty is void if the "Warning to Driver" decal is not properly displayed on the vehicle. No other warranties are expressed or implied. We reserve the right to make changes in design, materials and specifications without prior notice
Give Don a call he will set you up with everything you need.
http://thurenfabrication.com/
I second Don Thuren. His stuff rocks and is cheaper than you'd think. He uses the highest quality components and his customer service is second to none. He has called me more than once to keep me informed on the status of my rear King shocks.
Luken,
Talked with Don tonight and he said that everything is going well as planned. I have to get two brackets welded onto my frame and then measure so he can precisely fab up the rest of the components but the coils are in and the shocks are only a few days out. Then everything gets powdercoated (I was going to go YELLOW, but decided on metallic black to match the truck since I am doing the stealth theme) and it will be in the mail. The leaf springs I will have next week sometime. All in all I should be all done by the end of the year. THe only thing that might delay things is my schedule with the holidays. Chanukkah is a busy time; I have 8 presents to buy !!!!
