Straight Through Donaldson Muffler
Old 10-22-2007, 09:36 PM
Rednecktastic's Avatar
http://www.ryderfleetproducts.com/cg...uct_detail.jsp
Actually the M100582 is 51 inches.
What's the length of this one? I'm going to buy one of the two and I don't want it to resonate considering I'm removing all other obstructions.
Old 10-22-2007, 10:57 PM
alboy's Avatar
Is the donaldson quietier than the magnaflow.?I have the 4 inch magnaflow,quieter would be good.
Old 10-22-2007, 10:58 PM
DWitcher's Avatar
Originally Posted by Rednecktastic
I thought this was the 51 inch muffler?
Nope. 20" body. I have one on my 03 and one on my 95. Both with the plugs.
Old 10-22-2007, 11:01 PM
DWitcher's Avatar
I think the Donaldson is probably the quietest muffler you can get for the flow(CFM).
Old 10-23-2007, 12:08 AM
PEAKSTRYDE's Avatar
How loud is it in the cab??????
I went from a 4" MBRP str8 through to a 5" str8 pipe and my head hasn't stopped ringing since I switched!!!!!
Any chance of an incab sound clip?????? pppppppplllllllleeeeeaaaasssssssssseee
Old 02-07-2008, 09:42 AM
2003Ram's Avatar
What is the best fit for direct replacement of the stocker on a '03 - 4" in, 4" out? The 40" or the 51"?
Any additional parts required besides clamps?
Old 02-07-2008, 10:04 AM
Fisherguy's Avatar
If you have 4" factory exhaust you could use either one, measre the stocker and see which is closest. I went with the 40 cuz I didn't want it to be too quiet, but it's not loud by any means.
If you want the tail pipe angle to remain unchanges you'll beed some offsets since the factory muffler is offset.
I used 45" bends welded together, ratlratl used the 51" muffler but used a "muffler delete" pipe for the offset and it looks good.
See our galleries for pics.
Old 02-07-2008, 10:43 AM
2003Ram's Avatar
Good info ^^^
Thanks.
Old 02-07-2008, 12:16 PM
plug ugly's Avatar
are you guys running this stuff without the kitty, and thats why you need the donaldsons to remove the drone?
Old 02-07-2008, 12:59 PM
Fisherguy's Avatar
My cat's still in.
Some of the aftermarket mufflers are loud and drone when towing up hills or when under load.
Old 02-07-2008, 03:18 PM
PEAKSTRYDE's Avatar
My Kitty ran away.
I used the muffler to just simply quite the interior. Everything was rattling and I couldn't hear the stereo if it was less than about 18
If you leave the kitty in the system, it is not going to quiet it much!!!!!!!!
Old 02-07-2008, 09:27 PM
yaitsfast's Avatar
Installing my 5 inch 51" donaldson M090535 in the morning. Got it from Ryder Fleet products and it came in two days. Chasing down the drone like everyone else.
Old 02-07-2008, 09:48 PM
tcr
tcr's Avatar
Is that muffler strait through(no baffles) "5" ALL THE WAY THROUGH", or does it neck down internally?
Old 02-07-2008, 10:21 PM
Luvnacumns's Avatar
Yes it is straight through...
Old 02-07-2008, 10:23 PM
tcr
tcr's Avatar
51" And it stays a full 5" ID all the way though? If so it's the first of its kind.
Quick Reply: Straight Through Donaldson Muffler
