Stock Turbo Specs HY9 HE341 HE351
I'm looking for measured precise numbers for all 3rd gen turbos, 03-07 5.9L
HY9 (early 03 or maybe just SO's??) Need info
HE341(03.5-04 or maybe HO's??) Need info
HE351cw (04.5-07) 60mm compressor inducer/ 60mm turbine wheel/ 19mm wastegate port diameter. 67lbs/min corrected to Garrett test standards.
Any measurements you guys have would be great, maybe this could turn into a stock turbo measurement sticky!
As far as I know, the the HY9 was only available on the common rail. The HY35 is the 9cm housing turbo that came on 01-02 automatic trucks. That said, the HY35 is arguably the same turbo as the HY9 except the wastegate could be a different size and the wastegate spring could be a tad stiffer.
Thanks Soulezoo, I'm glad to hear a case of an 04' SO that dispels the HE341=HO myth.
So.... no one has a turbo laying around that they could mic?
koondawg
10-24-2012 11:11 PM
bmeyer2
0
08-30-2011 10:06 AM
The_Head
02-28-2009 04:00 PM
blownaway
03-13-2005 11:57 AM
