stock tune 62/71/13, will it throw low boost code? For smogging
Old 03-09-2010 | 07:30 PM
jmccart's Avatar
Hello. Like it says. Will I get a code if I put it on the stock tune for getting a smog?
Old 03-12-2010 | 02:27 PM
kuhkuhkyle's Avatar
Hey man. I run mine with almost the same turbo on the stock tune sometimes and I never throw a code. I run a 62/71/14. And it actually spools quite well.
Old 03-14-2010 | 01:12 AM
levigarrett76's Avatar
do you get any smoke?
Old 03-14-2010 | 12:44 PM
kuhkuhkyle's Avatar
I never do see any smoke when i turn it back to stock. Just the first time i stand on it it must break some loose. After that its all clear.
Old 03-14-2010 | 02:16 PM
sid325's Avatar
If you're running Revo just put your Smarty on level 1. The test only checks for codes, not what software you're running. I know one truck that passed the test running on level 5. That way, running Smarty on level 1, you won't have to worry about the possibility of tripping a code at the worst possible time. I'm more worried about passing with my HTT turbo....
Blake Clark
21
08-21-2012 12:35 PM
rebal
04-01-2012 11:05 PM
highrpms
03-16-2008 08:35 PM
daveg
13
02-01-2008 11:05 PM
Quick Reply: stock tune 62/71/13, will it throw low boost code? For smogging
