Stock Injectors vs Aftermarket (attn: DonM)
mine is set up to go from the walbro to the factory filter then to the 2 micron filter if you look at my pictures in my gal. you will see it there by the running board, little white thing. the trans cross member hangs lower then the filter so if the filter gets hit I have worse problems
RockGuy82
11-05-2009 12:55 AM
blackmoke
24
03-24-2007 09:46 PM
