Stock boost and pyro temp
what are you seeing for stock boost pressure and pyro temps? and when do u start making boost? what rpm do u reach before making max boost? No boxes?
My truck is stock and my boost will hit 32psi and my egts crusing at 70mph at just about 2000rpms are right around 800 pre-turbo, my max egts empty have hit 1250...
Originally posted by Blue600
I've hit 34 psi of boost and 1375*F preturbo I'm running stock.
Hey Blue,
Did you mount your boost tube in the horn or using a boost bolt in the maniford?
Thanks,
Mark
Originally posted by HighTen
Will a boost gauge yield different readings between these two installation methods? I was going to go the easier way with a boost bolt but if there's a question about accuracy, I want the accurate way!
lessismore
11-12-2010 08:50 AM
snowmanx
03-31-2009 08:42 PM
vwjunkie53
19
11-09-2007 02:27 PM
flashgordon
03-28-2006 08:47 AM
