Steering Stabilizer -- Recommendations?
I just ordered a Lorenz 2.25 system with the dual leaf upgrade, and now I'm looking for a steering stabilizer. I'll be running 37" Toyo MTs, so I probably need something a little more robust than stock.
The problem is, I can't find anything available to fit my application. I like the Carli/Defiant dual setup (even though it's a little pricey), but I understand that it won't work with the MagHytec front diff cover I have.
It looks like Don Thuren, Kore, and Radflo offer a single stabilizer design that will work with the MagHytec, but they all mount in a location similar to the stock setup. Last time I went offroad on some mild trails, I came back with a dented and bent OEM stabilizer, so I'd like to go with something that is in a more protected location, or has a guard incorporated with it. I'd hate to repeatedly spend $250 - $300 for an upgraded single because of it being the lowest hanging part on the front end.
Does anyone know of a product that will work? Any experience with the Superlift SS select series? Any suggestions will be appreciated. Does a dual Carli/Defiant setup exist that will work with the MagHytec?
Thanks, Eric
Thanks, Eric
Thanks Pauly. You're running Thuren's Fox stabilizer right? Do you know if it will clear the front diff MagHytec? I know it is somewhat longer than the stocker, but does it extend as far as the front diff? --Eric
Yeah, I have Don's setup.
It looks like it will clear. There's some adjustment in the angle of the drag link mount that make me think it will clear, but I haven't seen the Mag cover close enough to know for sure.
When you get a chance, run out and take some measurements and I'll compare them to my truck and maybe we can figure out if it will fit or not. Turn your wheels all the way to the left and see how close the drag link comes to the cover.
I used both Thurens's Fox and now Defiant Sinlge Stabilizer. Thurens made my truck's front end a little loose feeling (pulling left or right depending on presssure). Played w/ different pressures and no go. So I decided to go w/ Defiant single. I went w/ the single instead of duals after talking to Paul at Defiant and Glenn at Radflo. Both basically said how I drive my truck and w/ 35" tires. The single will be efficient. Granted if I was taking my truck off road and gnarly places every week. I would defianetly go w/ the duals from Defiant.
It works good and more durable than the stocker. Paul Fox said the shock is between an Emulsion and IFP using both concepts.
mercedeezel
13
10-13-2013 12:43 AM
EdmontonCanada
07-20-2010 03:57 PM
1985cucv
07-31-2009 02:33 AM
Rattlerattle
08-19-2008 04:14 PM
13ALPHA
07-08-2008 11:31 PM
