stacks with bedliner
Old 08-28-2005 | 01:51 PM
harleybill38's Avatar
can I run stacks with my plastic bedliner?will they melt it?and what if I want a spray in bedliner later,will that melt?
what sounds better,5" pipe like comes in the kits,or a6"x6" steel column with stacks mounted to it? would 6x6 be deeper? I would rather learn in advance from those of you that have already done the trial and error
thanks in advance
Old 08-28-2005 | 02:03 PM
RamWheelsBy4's Avatar
I have seen a number of trucks with spray in liner and stack(s). Looks like they just give an 1" or so clearance around the pipe coming through the bed.
Old 08-29-2005 | 09:41 AM
StevenB05's Avatar
I have stacks with a spray-in liner and have had no problem's yet. I also have the 6x6 tubing across the bed and then my 5" stacks with turn outs. It's pretty loud straight piped but it has a good deep sound.
Old 08-29-2005 | 12:53 PM
TexasRamMan's Avatar
Where do you find the kits? Website? Local big rig shops?
Old 08-29-2005 | 07:35 PM
ramman,do a search here under exhaust stack kits,or 5' stack kits,etc. and some of the guys say where thet bought there kits.I am trying to weld two 5" pipes to a 7" pipe with a 4" pipe underneath,will let you know if it works.
Old 08-30-2005 | 01:27 PM
RamFan72's Avatar
Heres a site that has quite a few packages, looks like pretty good quality stuff too
http://www.blackclouddiesel.com/Stacks/stacks.htm
Old 08-30-2005 | 05:18 PM
I welded up my 5" stacks to my 7" pipe across the bed hooked into exhaust pipe with flex,sounds amazing I drove with the radio off all day.
good chrome 5" turnouts only $85.00 each,flex and tube all about $200.00 total,sounds better than a kit.really sounds great though and looks cool with smoke pouring out.got that new truck feeling again.probobly the best $200.00 you can spend on your truck
Old 08-30-2005 | 08:55 PM
B.Law's Avatar
I have a Bedrug beliner and I am running stacks with no problems. However I covered the x-over piping w/ header wrap just to be safe. If you are worried about it just do the same. There's a guy on eBay that sells 100' rolls all day long...
Ridiculous
05-17-2007 10:00 PM
nfsommer
21
04-04-2007 04:45 PM
RYANGRAPHITE600
05-29-2006 02:26 AM
rockittboy
02-03-2006 01:38 AM
PistolWhipt
32
02-19-2003 05:40 PM
