Stacking JuiceW Attitude/Quad XZilliraider Race
Anyone tried stacking the new Xzilliraider 2 with an edge juice with attitutde??? What levels should I run on both??? How should I hook them up (do they share any hookup points if so who goes first)?????
Guest
Posts: n/a
Yep, and it's a great stack!(at least on my 04.5 it is) Not sure on the 06 but on mine the Edge uses the data port and the X2 is left disconnected. On mine the X2 connections are first.
I run the X2 on LVL 2 or 3 and the Edge on 3-5 most of the time. I haven't tried the X2 turned up with the Edge on the lower settings only because I want to keep the pressure at a minimum.
Tons of power, very smooth delivery and not a lot of smoke unless the Edge is turned up and I lock the TC. Your stock trans ain't gonna like you very much or for very long if you rail on it though, but I'm sure you know that.
Guest
Posts: n/a
On the X2 you can download stacking tunes that are fuel only That's what makes this box so cool. Check out Quads website and see what tunes are available now and there's gonna be a whole lot more according to Quad. May even be custom made to order ones at a later date also
justin mcfall
22
01-30-2008 10:48 AM
CDoskocil9
03-27-2007 10:37 PM
