Stacking Edge Juice
Old 01-12-2008, 07:29 PM
J-man's Avatar
Stacking Edge Juice
What are the best options to stack with Edge Juice with Attitude?
Old 01-12-2008, 07:44 PM
Administrator/Jarhead
madhat's Avatar
I have an MP-8, it's pretty good. Ads about 40 lb/ft of Tq.
Others say an EZ, I'm not 100% sure if I'm right about that...
Old 01-12-2008, 08:05 PM
J-man's Avatar
You say that it adds torque but no h.p., huh?
Old 01-12-2008, 08:12 PM
madhat's Avatar
Well...
I'm sure it does. Gimme a minute, I'll pull up the dyno sheets from the run without the mp-8, and the one with it. You have to consider the mods that I have, the fact that it was different days, different dyno's, and different weather. The first run on the second dyno was with the MP-8 off, the second one was with it on...
Old 01-12-2008, 08:13 PM
madhat's Avatar
Check this out...
https://www.dieseltruckresource.com/...9&postcount=32
Old 01-12-2008, 08:29 PM
J-man's Avatar
Do all stackers just add fuel, or can some add more than that? Also, do other boxes, like the EZ provide about the same help as the mp-8?
Old 01-12-2008, 08:30 PM
J-man's Avatar
Madhat, when you use your mp-8 how does it effect your mpg's?
Old 01-14-2008, 10:47 AM
tantruck's Avatar
The Edge EZ and Mp-8 are pressure boxes. They both stack well with the Juice boxes. But stay away from stacking two pressure boxes. My 2004.5 likes the Hot Juice(non-pressure adding) with my Edge EZ on level 2 of 3. I believe you can get some year Juices that add pressure therefore, I wouldn't add an additional pressure box to those.
Old 01-29-2008, 06:10 PM
btolenti's Avatar
so I bought an EZ on ebay....to stack with my juice....and Edge says this is a no no....
Brandon,
The EZ and the Juice with Attitude are not designed to stack and it won't actually work. The Juice Att can stack with programmer type of modules but there is no way to piggy back an EZ as it is an in line module just like the Juice. Let me know if you have any additional questions.
Edge Products Technical Support
1080 S. Depot Drive
Ogden, UT 84404
Toll Free: 888-360-3343
Local: 801-476-3343
Tech Fax: 801-337-2198
Email: tech@edgeproducts.com
Edge Products: Home
mb
*** Due to the large volume of e-mail we receive, PLEASE include previous e-mails when responding. This will allow us to read the complete dialogue in one message and will result in quicker responses. Thanks! ***
Sent: Mon 01/28/08 4:15 PM
To: Edge Tech
Subject: Edge Juice and EZ stack
I have the following on my 06 Ram:
Edge Juice w/Attitude : EJD3000B
I just purchased an Edge EZ (EZD1000D) to stack with the Juice. How do I connect both modules at the same time? Which module connects to the MAP sensor first?
Thanks!
Brandon Tolentino
The information contained in this communication and its attachment(s) is intended for the use of the individual to whom it is addressed and may contain information that is privileged, confidential, or exempt from disclosure. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying is strictly prohibited. If you have received this communication in error, please notify administrator@edgeproducts.com and delete the communication without retaining any copies. Thank you.
Old 01-29-2008, 06:23 PM
omaharam's Avatar
I would call them and ask them why they have the janitor responding to emails.
It will most certainly stack. The ez is a pressure box and the Juice does timing and duration. Hook up the ez to the sensors, the juice to the ez, and the factory plugs to the juice.
Not trying to say I know more about Edge than the Edge tech guys, but that must have been that guys first day or something. Many people, including myself run a pressure box with the juice and it shouldnt' matter which one. I have run two different ones but not the ez, but there is NO reason it shouldn't work and I'm pretty sure others have run that stack.
Old 01-29-2008, 06:32 PM
skynyrd's Avatar
the edge juice and ez can be stacked. the ez gets plugged into the map first.
Old 01-29-2008, 06:51 PM
btolenti's Avatar
I read a whole bunch of posts saying exactly what you two said, but wanted Edge's reply......not sure who answered the e-mail question.....
Old 01-29-2008, 06:54 PM
madhat's Avatar
It does better... I run at 50% normally, and I see 1.5-2 MPG.
Old 01-30-2008, 10:23 AM
btolenti's Avatar
Ugh, I heard the juice plugs in first.....can anyone verify which goes first?
Old 01-30-2008, 12:05 PM
madhat's monkey boy...
matego's Avatar
You plug in the pressure box first. The Juice alters the map signal and you dont want an altered signal going into your pressure box. Pressure boxes have very specific maps for certain boost levels and you dont want your pressure box commanding too high of fuel pressure to your injectors.
This is my take on it from talking to different companies that make pressure boxes. Ask Quad, he will know 100%
Quick Reply: Stacking Edge Juice
