Stackin the juice
Stackin the juice
Hey all!
Worken in a truck runnin a juice/a2 setup. Whats the best stack with the juice. And why is it the best stack.
Is everything still just plug and play? Is there a "safe" (reliably) stack
On otherwise stock truck, stacking anything with the Juice probably won't help a lot. You will need more air and maybe upgraded LP to really use on higher settings. And you will also have enough power then to waste a clutch or tc/transmission.
That said, the Edge EZ or the TS Performance MP-8 are about the most used pressure boxes for stacking.
I had the EZ stacked with my Juice/Attitude and HOT Juice/Attitude. No problems or issues for me.
i have tested alot of stuff with my juice the power pup and the edge ez not all together of course but i found a lot of power with the ez and the juice together and better fuel consumption try it had no probs
what year is the truck?
I would think you just want a presure box and prefferable ajustable I would think. that way you could mess with it a bit to try to optimze the power.
04.5 and up are all timing and durations. 03-04 have a bit of presure in the juice programing.
no first hand experiance but I would look for a used ez on ebay as that would be the most economical approach. Many people unoading them to upgrade to something with more power. I don't know how much presure the ez or mp-8 add to compare them.
big_bear_92007
07-09-2008 02:14 AM
djcheez
10-15-2005 05:13 PM
SjLingenfelter
09-09-2004 03:39 PM
