stack with the smarty
The TST is one of if not the best overall. But it is really for fairly high horsepower and requires enough mods to support the stack.
Some are having good luck with pressure only boxes. I have seen posts on EZ, Quad XZT and MP-8 that seem to be working well.
I have TST and EZ stacked with mine. EZ and Smarty only also works fine on mine.
tst is stacked on my smarty. seems to good so far. cant turn on high levels at the moment because of high egts. when I get a turbo in a week im going to run it a little higher. It seems to run pretty strong but im running out of fuel in the rail I believe
Even if it's a pressure-only Quad box, won't it still indirectly add timing since it's altering the MAP and rail pressure sensor readings to the ECM?
Topper
03-03-2008 10:17 AM
white250005
10-25-2007 10:19 PM
B.Law
16
04-22-2005 02:28 PM
Cat Cracker
07-14-2003 12:17 PM
