sps 66 or ps62???
Old 11-02-2005 | 01:02 AM
lightening ram's Avatar
sps 66 or ps62???
just curious why everyone buys the sps66 instead of the ps 62 turbo the performance shop around here is trying to push the ps62 but i want the sps66 they said for my application and towing the sps can get out of hand when spooled up and i run a 91% torque also may give me some turbo lag taking off, is this all true?
Old 11-02-2005 | 01:21 AM
BigBlue's Avatar
The sps66 is slower spooling than the ps66 because it's bigger. For towing you don't want a slow spooling turbo and with your 91% TC your gonna notice the lag.
Old 11-02-2005 | 02:47 AM
PourinDiesel's Avatar
If you are going to tow get the 62 version.
You will be alot happier with a faster spooling unit.
Old 11-02-2005 | 01:02 PM
AK RAM's Avatar
Do they not make a 64mm version? Seems that would fit most peoples' agenda a lot better since the 62 is not a lot of improvement (for the cost) and 66 being too much for most people. If not, what is wrong with HTT's 64mm turbo, the "Killer 64"?
Old 11-02-2005 | 01:07 PM
Luken's Avatar
I talked to Brett last week and he said they had a 64mm. I really want the 66 but I pull 10000 every now and then and he said with the auto it wouldnt be the best option.
Old 11-02-2005 | 01:46 PM
wap's Avatar
wap
Would a 64 be much better than stock for the money?
Old 11-03-2005 | 07:34 AM
Goggleyed's Avatar
I don't know about other trucks, but the PS62 made a huge differance on my truck. No regrets here!!!
Old 11-03-2005 | 11:22 PM
i think i should maybe run the 64 also i pull heavy loads also.
Old 11-03-2005 | 11:58 PM
Patriot_RAM's Avatar
I love my SPS66 -- but I don't tow. If I was towing, I would have gone with the PS62 because it spools up faster. My EGTs get a little high until the 66 gets spooled. Nothing worth worrying about, but it might be if towing. The 66 responds very well for a large turbo, but still a little laggier than I would want towing. Just my two cents...
Either way, stick with the PS series!
Old 11-04-2005 | 02:30 AM
John Rodriguez's Avatar
Tire Hater
Well, I towed a small trailer again, grossed at 17,9 and the pressure box helped get the turbo spooled fast enough that lag wasn't really a problem, and not too much smoke if you're in the sweet spot from getting the turbo spooled between bogging and being an EPA star member.
Old 11-07-2005 | 12:54 AM
turbo
i have a choice from all 3 the 62, 64,66 so ill do some home work and see which one is the best bang for the buck, my truck is pretty quick now so i like to see it with the 66, i wonder if there is that much of a difference between the 66 and 64, any one tried both or rode in trucks with similar setups that had both??
Old 11-07-2005 | 09:01 AM
Agades's Avatar
im running the 62/ 14cm
I tend not to run high rpm's and my temps climb fast when towing till she spools
I really wouldnt want anything slower spooling than I have now
if I keep the rpm's up a little its a beatiful towing turbo
just wish my clutch would hold
jmccart
32
04-01-2008 09:50 PM
natlchamp2k4
01-28-2007 10:35 PM
Smkn600CTD
03-30-2006 06:25 PM
gsdog1
11-27-2005 11:59 AM
sshelly
10-11-2005 09:23 AM
