Speedo Recalibration on 06's..is there a way it can be done yet?
Old 10-30-2006, 05:30 PM
06Cummins's Avatar
Im looking at going with 35's for my truck and all i have read is that there is no way to adj the speedo on the 06 up trucks for the new tires. Is this still true or can it be done now? Thanks, Jason
Old 10-30-2006, 05:32 PM
rustyshakelford's Avatar
superchip #3805 can do it!! also the dealer can do it im told. not sure what the max tire size they can change it too though
brett
Old 10-30-2006, 05:33 PM
ptgarcia's Avatar
Last I heard the dealer could only go up to a 285/70-17 size tire.
I'm not going to do mine. I just don't see a reason why I should.
Old 10-30-2006, 05:37 PM
D.Wiggs's Avatar
A smarty can go from 25"-45" tires in .05" increments. Also, the dealer can go up to approximately 33.4 I think it is. It's something on a 19.5" rim. They can also adjust gear ratios down to 3.21.
Hope this helps!
Old 10-30-2006, 05:39 PM
Boz007's Avatar
As has been said, the dealer cant adjust for 35's. I was finally able to get mine correct using my Smarty. Its nice to know how fast im really going.
Old 10-30-2006, 05:45 PM
973604x4's Avatar
Even if the dealer recalibrated it, when you load the bullydog on it I'm not sure how it would work.
I had my dealer calibrate for my tires and then went and tried to do a "try before you buy" thing from bullydog. The bullydog read the computer as already being programmed since some parameters weren't stock.
Old 10-30-2006, 08:24 PM
06Cummins's Avatar
hmm well it looks like i might be getting a smarty too...lol. thanks guys
Old 10-30-2006, 08:29 PM
D.Wiggs's Avatar
Go for it! You WON'T be dissapointed!
Old 10-30-2006, 08:34 PM
Argo's Avatar
just use GPS and save your odometer
Old 10-30-2006, 09:07 PM
973604x4's Avatar
I thought about saying that....
Jason-
I just called my smarty dealer....I am working on one for you and another guy in town. Hope the smarty works better for you than it did for me. I'm gonna get a Smarty for you to try out for freeeeee....but only for a short time.
Old 10-30-2006, 09:58 PM
ptgarcia's Avatar
Do you really look at the speedo that much anyway? I don't. I can pretty much tell how fast I'm going by feel. Keeping pace with traffic is another gauge.
Old 10-30-2006, 10:52 PM
Longhorn06's Avatar
I had mine done at the dealer, and yes 285/70/17 is the largest tire that the dealer can recalibrate to.
Old 10-30-2006, 11:38 PM
06Cummins's Avatar
Originally Posted by 973604x4
Jason-
Sweeeeeet
Old 10-31-2006, 07:20 AM
oldmandan-1's Avatar
Just wondering.....I have an 06 smarty on the way. I have 35's on my truck, what tire diameter have some of you entered that seems to calibrate the closest?? I know on my 01, you couldn't enter the exact height.
Old 10-31-2006, 07:34 AM
UnrulyNFS's Avatar
You don't enter tire height usually, you enter revolutions per mile. Anyways, just research the exact tire you have on that companies website and it usually will tell you revs per mile and actual tire height. My 40's were something like 39.8" tall and so many revs per mile. And since the smarty can adjust the tire sizes on my '06. I'm gonna order one as soon as I get my twins on. Right now my speedo says I'm going 62 when I'm doing 75. I use a GPS to keep actual track.
Quick Reply: Speedo Recalibration on 06's..is there a way it can be done yet?
